Anyone done 1000 mile service and only drained 2 or so qts?
I forgot to check the dipstick before I drained the engine. But I poured all the drained oil back into the new oil bottle and only had 2.25 quarts. I even drained the filter too. I know that the filter media has some oil in it but I expected to drain what I put in, which was 3 quarts. I did not over fill. Dipstick level is at full when hot. Oil was drained for 30 min. while level on bike lift.
Stupid me took for granted that oil was topped off at purchase, since it's a new bike. Have any of you found that your new bike was not full? I have read that past Harleys are known to consume some oil during break-in. Is this true?
There will always be oil left in sump after draining.This is why they say to fill with 3 quarts and then check level.Leaving low oil level to keep oil from puking is not going to make any difference.Would You leave Your oil level in Your car low for any reason?Look into a crankcase breather bypass to keep oil from puking.
I am looking at bypasses. J&P sells a nice one with braided hose fro $67. You can get cheaper kits or piece one together cheaper.
http://www.jpcycles.com/product/4000380
My bike doesn't do this enough to make a difference in oil level but I can see some oily residue on the bottom of the air filter backplate where it leads into the throttle body. I'm going to vent it to outside of the air cleaner housing.
My 2015 flhtp drained 2.75 qt including oil filter. I followed manual and started with 3 qts...NOT. That put me a little over full when hot.
My 98 heritage doesn't like to be over 1/2 between add and full and that's what I have now in my new one (after draining 1/4 qt)
Start with 2 1/2 qts THEN check hot and see where you are would be my idea
And that tranny dip stick is useless to me...cant read it worth a ****.
28 oz and call it good for me
