FP3 question
I have the S&S air cleaner and S&S power dual headers along with Jackpot 3.5 mufflers from Fuelmoto. I am using the FP3 for my EFI tuning and I am running it in the Autotune mode currently. My idle seems to be rich and running rough. I don't have a lot of green blocks yet maybe 15%. I am going to finish out this tank of gas and see how it is running then. I love the ease of use of the FP3 and really hoping I can get it tuned just right! BTW as Smitty said I have also had issues where the bike does nothing when I hit the start button. It has however always started maybe after just a couple of presses.
You have to hit the start button when the red light goes out
Not right now, but they say it may in the future. Id go PV if I were you
I just think V&H needs to work stuff out.
I also do not get a "0%" TPS with a closed throttle wether running or off. It's at 5% running or off and 3% while driving.
VE's run off MAP so it's not affecting the tune per say, but the decel enleanment has to be affected since it reports a somewhat open throttle in my opinion.
I get pops (not bad though) on decel under 2,000 rpm and get no results from using this table to try to tune it out (no exhaust or intake leaks either)
I was only going with a Stage One and went wit the FP3 and had zeros problems and bike runs great. If I were do all over I'd go with the same set up again. What I was wondering will the Canbus on the 2014's adjust the tune and settings more after a tune is loaded? Heard that after a tank or so the computer will fine tune adjust .. not sure if this is true or not?
Mine shows between 3-5% under any closed throttle situation. I wonder if they all show that.
