Big mistake -- oil change --
on my first oïl change on a road king 2004, I used the crank plug instead the oïl plug to drain the engine oïl, it did camme out 4 pint of oïl, but is this danger to my engine and crank,...
I didn't post it to be funny. I was afraid to change my oil because of all the threads where people make this common mistake. I found this picture on the oil stickie. It is a picture they should have in the service manual. At least in the '03 manual there are no pictures or diagrams.
Here was a similar thread.
https://www.hdforums.com/forum/touri...raining-4.html
If you do a search you can see this happens quite a bit. It would be nice if some of the people who have done this would update us on if it ever caused problems.
This is the reason they make Shop Manuals. By the way, EVERYONE should own one so you don't make dumb mistakes!
HD Service manual:
The owner's manual actually has a better diagram, which I didn't realize, because everybody on HDF always tells you to get the Service manual.
