Real 100% synthetic engine oil
Oil topics can turn into a McGregor/Mayweather scene....lol.
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
2. The filter only removes solids; it cannot remove bad liquids like acids that form in the oil.
It's best to follow the manufacturer of the oils recommendations. They are over-cautious as they don't want to be sued; but do you really want to risk ruining your $40,000 super, duper, glide?..just save $30 on oil?
If you really want to push the oil life past what is recommended, send in a sample to be analyzed. As long as your driving habits remain about the same, one oil analysis will give you a good idea on how far you can go between changes.
What I typically do is change it each season no matter how many miles under the manufacturers limit. I then run that oil through a home made filter using a 1 micron water filter element and then use that oil in an old car and my lawnmower.
