Oil Archive (no new posts) An archive of oil related questions and comments.
Oil change mistake!
Old 06-10-2017, 08:54 PM
killerqhk's Avatar
killerqhk
killerqhk is offline
4th Gear
Default Oil change mistake!
Hello guys,
I have just done a poor job on changing oil on my Sportster XL883C (Please don't ask me why because I am new and couldn't wait to read all instructions).
1. I didn't pour oil into new oil filter.
2. I didn't remove the plug from the hose until seeing some oil (removing air bubbles.)
Therefore, when I pour 3qt into the oil tank, it was totally full . Do you think oil would pour into the oil filter if I open the oil cap? If it doesn't, what should I do? Please help me. Thanks
Old 06-10-2017, 08:56 PM
QC's Avatar
QC
QC is offline
Received 19,786 Likes on 9,863 Posts
Start the bike. It'll take about 10 seconds for the filter to fill. Unless I'm missing something special about Sportster oil systems.
The following 2 users liked this post by QC:
killerqhk (06-10-2017), perki48 (06-10-2017)
Old 06-10-2017, 09:38 PM
Yamaharley's Avatar
Yamaharley
Yamaharley is offline
**** I don't pre fill my filters. The car yes, the horizotal bike one... Good luck. You did good. Mabye put in 2.5 qts next time just to make sure it doesn't overflow and then after its running top it off.
Old 06-10-2017, 09:48 PM
perki48's Avatar
perki48
perki48 is offline
Received 4,099 Likes on 1,913 Posts
Don't worry about it. Start the bike and oil light will go out in just a few seconds.
Old 06-11-2017, 07:26 AM
1340hog's Avatar
1340hog
1340hog is offline
the older evo engines you had to fill the fillter some because of the low flow sump system.the way i understand it on those engines with an empty filter it could air lock and therefor have no oil circulation for way to long,not good.the newer engines have a higher flow oil systems so i guess it dose not matter.on my old bike i always filled the filter half way,or full to the point where when you tip it in place it dose not spill all over the place.i continue this practice on my newer bike even though i don't have to.but keep this in mind, untill the filter fills with oil there is no pressure in the system.no pressure means no flow to some parts of the engine.with high flow systems the fraction of time is minimal, so how much does it hurt? who knows.
Old 06-11-2017, 07:30 AM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
More important question...what kind of oil did you use??
Old 06-11-2017, 07:44 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,921 Likes on 3,021 Posts
And where do you put your gas cap when you fill up?
Old 06-11-2017, 08:19 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,497 Likes on 4,612 Posts
Dont forget the classic:
Is your clothes dryer vented into the garage?
Old 06-11-2017, 10:49 AM
killerqhk's Avatar
killerqhk
4th Gear
I use 20w50 oil from Harley local store, and I don't touch the gas cap when I change the oil. Do I have to remove it when changing oil?
I have just checked the filter, and oil was filled in the new filter. I did remove the plug from the hose until seeing some oil. For now, everything seems to be perfect .
perki48 (06-11-2017)
Old 06-11-2017, 11:11 AM
Zerk's Avatar
Zerk
Zerk is offline
I have wondered about pouring some in filters, in general. But then I also think, they have been dry for many oil changes.
You could probably pour a little in, even though horizontal. I didn't last night, but I was drunk.
Quick Reply: Oil change mistake!
