Oil Archive (no new posts) An archive of oil related questions and comments.
Oil Mixing Question
Old 10-20-2017, 09:14 AM
hd4evr2008's Avatar
hd4evr2008
hd4evr2008 is online now
Received 1,823 Likes on 821 Posts
Default Oil Mixing Question
Maybe a strange question, but here goes.......I changed the engine oil in my bike yesterday. I use Mobil 1 V-Twin. My bike takes 4 qts (actually 3 1/2). Anyway, I have 1/2 qt. of Mobil One left over, and I want to change my primary oil today. I use Formula + in the primary, which takes 38 ounces, or 1 qt., 6 ounces. My question is this...instead of buying a whole extra qt. of Formula + to get the extra 6 ounces, can I use the extra Mobil One oil I have left over, and mix it with the Formula + to top off the primary? Will it "mix" OK, or would that be a no-no?
Old 10-20-2017, 09:19 AM
twoglides13's Avatar
twoglides13
twoglides13 is offline
I think that it is a terrible idea, bite the bullet and buy another bottle of formula +.
Old 10-20-2017, 09:35 AM
ChunkChunkChicken's Avatar
ChunkChunkChicken
ChunkChunkChicken is offline
Agreed...spend the 6 or 7 bucks on the +. Geez.
Old 10-20-2017, 10:46 AM
hd4evr2008's Avatar
hd4evr2008
6 or 7 bucks for 6 oz. of oil....nope, first off, it's $9 for a qt of Formula + at my dealer., btw......so, do I pay $9 for an entire qt. when i only need 6 oz. of oil, when I have 1/2 quart already sitting on the shelf?........sure.....why not?
Old 10-20-2017, 10:57 AM
ohioflhs's Avatar
ohioflhs
ohioflhs is offline
You will need them again. Just save the rest for next time.
RedneckRob (10-21-2017)
Old 10-20-2017, 01:56 PM
Qdog002's Avatar
Qdog002
Qdog002 is offline
You can mix different brands of oil and or synthetic with dino oil but NEVER mix the viscositys of motor oil.
Old 10-21-2017, 08:32 PM
xcbullet's Avatar
xcbullet
xcbullet is online now
I've mixed all kinds of stuff. It will be fine. If u want use 6 ounce of trans fluid.
Old 10-22-2017, 09:02 AM
bustert's Avatar
bustert
bustert is offline
you will be surprised at what the bottler does. after a production run, do they throw away left over vat?? hardly, they use it even if in another mix of compatible base. end result oil product is mostly about additives and not base stocks.
this issue i see in maintenance. i have a 1974ch that ran the whole gammit of oils, used what was handy so multi weights, straight weights and a whole gammit of weights from 30>80. i prefer straight weight in the 40>50 range but getting harder to find and a series 3 diesel oil if possible. the end result is 150k and virtually zero wear.
i deframed the engine for frame paint so bird in hand, decides to up the ponies. the pin wear was really not detectable since i did not have original fit but to the book, less than 1/2 ten thousandths. the jugs had .006 taper and a .010 over bore cleaned that up, i now have over 175k and ready to bust the 300k. since the ch had no filter, i over killed it with 2k oil changes and now 3k since i added a filter system.
Old 10-22-2017, 09:10 AM
PDB17UltraRG's Avatar
PDB17UltraRG
PDB17UltraRG is offline
Depend on your Bike the new models 17s and. Newer use Motor oil in all 3 holes but the older models use three different oils, they primary oil for a reason why take a chance to save 7 bucks
Old 10-23-2017, 08:22 PM
muddmann's Avatar
muddmann
muddmann is offline
Get another quart of Formula +, use whatever of it you need. Then for the next change you will only need to purchase on quart, and use the remainder of what's left to top off.
Quick Reply: Oil Mixing Question
