Redline vs. Amsoil
#31
5. When it comes to "Viscosity additives"...the less, the better. https://www.bobistheoilguy.com/oilshear.htm
6. " Most modern synthetic oils will last well past the recommended service intervals from both a viscosity and lubricity standpoint".
This is mostly true with a car or liquid cooled cycle, but we're talking GIANT, air cooled, Harler's here. Viscosity is CRITICAL...Go read the thread where folks post their oil reports...time and again, oil with just 3/4/5000 miles, has sheared to 40 weight or less.
7. Changing often is better than relying on "the best", and most expensive, oil to protect against wear for extended intervals.
I've stopped at 7, but there are many more facts stated...and anyone that reads through this post and comes away with only one "fact" of "clean oil is best" has a serious reading comprehension issue.
if you wish to go on about how much you know about why engine oil additive packages are bad, then feel free .. but FACT ... they are 100% necessary. Remember I never said more is better, only that they are necessary to some measure.
The following 3 users liked this post by harkon:
#33
"The only factual recommendation stated here is that contaminants are bad. Clean oil is best"
BS.
Facts Stated:
1. A quart of oil is not 100% oil.
2. Some of that quart is friction fighting chemicals = good with bad added in...ZDDP adds to carbon buildup and ruins catalytic convertors..which is why motorcycle oils carry a 21 year old, obsolete, API rating.
3. Some of that quart is "viscosity improving" chemicals = good AND bad! - bad because those chemicals take the place of other "good" chemicals and "viscosity improving" chemicals will shear, turning 60 weight oil into a 40 weight oil fairly quickly.
4. HARLEY recommends straight weight oil under certain conditions! This is because the initial cold startup wear is FAR LESS damaging than engine wear due to hot oil that has sheared to 30 or 40 weight.
BS.
Facts Stated:
Are you in any way related to Cliff Claven?
#36
I switched to 100% AMSOIL in both my truck and bike for ALL fluids (everything but transmission fluid in truck).
I change my oil at regular intervals and while I do run my vehicles hard, I take care of them. So I'm not worried at all about having an oil related failure. I noticed my bike seems a little happier running AMSOIL than the Lucas that was in it. and I'm a preferred customer so the pricing is actually cheaper than anything I could buy (that I would put in my vehicles) at any retail location in town, and I make a few bucks buying and selling oil to friends.
Dan89FLSTC (02-18-2018)
#38
Religion, politics, and oil.
Used to be a guy on this forum with 150k plus on a bike that never had anything but Wal-Mart super tech 20w50 conventional in all 3 holes since the first change. But since it wasn't high priced syn it probably wasn't the best oil. Guess his bike didn't know any better. It just kept going.
#39
I ran 6500 miles on Amsoil 20w-50 one year. When I changed it at the end of riding season, I sent it out to be to a lab the report came back saying I didn't need to change it.
#40
What were the particles in the oil and what was the size count?
The oil itself will stay "good" for a very long time; but it's the particles in the oil that wear the engine...mainly carbon from the burnt gas..that is why you need regular changes.
