Oil Archive (no new posts) An archive of oil related questions and comments.
engine oil
Old 01-20-2018, 07:25 PM
FOCI's Avatar
FOCI
FOCI is offline
Default engine oil
while we are in winter how long should the bike run if you start it
Old 01-20-2018, 08:29 PM
nicktown's Avatar
nicktown
nicktown is offline
Don run the bike till you can ride it. Running it in the garage, it won get hot enough burn of the moisture that will collect in your oil. Not sure though, I think it takes abour 8 miles to get to oil warm enough to burn off the moisture that collects in your oil.
Old 01-22-2018, 04:59 PM
st john's Avatar
st john
st john is offline
nicktown is very close to right on. just remember at 50 degree weather yes 8 to 10 miles, but at 30 degree you may want to go 15 to 18 miles.
Old 01-23-2018, 12:06 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
I would say around 20 miles for any short ride in cold weather.
Old 01-23-2018, 04:18 PM
st john's Avatar
st john
st john is offline
I will go along with grbrown, what do I know about cold weather I ride in Arizona. :-)
Old 01-24-2018, 05:40 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,784 Likes on 3,300 Posts
Usually till the motor is up to full operating temps....
Old 01-24-2018, 10:29 AM
skidder's Avatar
skidder
skidder is offline
When the tranny is hot to the touch you got it cooking enough.
Old 01-24-2018, 09:46 PM
bustert's Avatar
bustert
bustert is offline
short trips can be hard on the oil but one has to keep an eye for the tells. if no tells, probably doing fine and a few here and there will not hurt. my oil really never warms up to the point of boiling the water out even in the summer. do i have condensation issues, nope. most of the blow-by will be hot gas and a little water which most of it will vent. so a no.1 tell would be in the air cleaner.
now just to oil up an engine for a few seconds of run time probably won't hurt either since you are only talking about what 3 months of winter with maybe a good run in between. what does hurt is running on enrichment which contaminates the oil with fuel and can wash off cyl lube.
Fastfwd
Engine Mechanical Topics
49
07-27-2020 01:57 PM
CDW
11-02-2010 08:36 PM
bikerick
34
01-09-2009 01:25 PM
Dancemax
04-03-2008 08:28 AM
swomack
10-26-2006 04:04 AM
Quick Reply: engine oil
