Oil Archive (no new posts) An archive of oil related questions and comments.
Dino vs Synth with M8?
Old 02-08-2018, 10:24 PM
NugBa's Avatar
NugBa
NugBa is offline
Default Dino vs Synth with M8?
NO DEBATE ON OIL HERE PLEASE!
I'm nearing my first 1,000 service and I have always been a believer in synthetic. Not a huge fan of Harley Oil but I stick with it since I have all my service done at dealership. When I had my Ultra limited I did notice the engine seemed to be a little more tap heavy when using synthetic compared to dino oil. I was told as far as the Harley branded oils go, their synthetic does make the engine tap more then the dino.
I'm still going with Synthetic and with the new M8 I will start it at the 1k oil change rather then the 5K I did on my 103 ( I have my reasons and i'm comfortable with that). Does the new M8 engine exhibit the same behavior that my 103 engine did when running synthetic?
John
Another Very Happy M8 Owner!
Old 02-09-2018, 07:17 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Talking
John, there's a dedicated M8 section, where you should find more members of them. They're probably so busy talking 'oil talk' they don't often call in here!
The following 2 users liked this post by grbrown:
SPRINGER (02-12-2018), Uncle Larry (03-31-2018)
Old 02-09-2018, 07:59 AM
PDB17UltraRG's Avatar
PDB17UltraRG
PDB17UltraRG is offline
Try the Oil section
Old 02-09-2018, 08:33 AM
PDB17UltraRG
I would use what the service manual recommends been using SYN3 for that reason. Oils are the owners choice now a days there made very well with very little difference between them other then color and weight. There so many debates out here just fine what’s right for you.
Old 02-17-2018, 03:50 PM
smitty901's Avatar
smitty901
smitty901 is offline
Received 9,554 Likes on 5,152 Posts
Comes down to what helps you sleep at night. Standard oils and lubes work change as required and ride. Know many that have put a lot of miles on using nothing but regular oil and lube.
No arguing syn stands up to heat better. Is it necessary who knows.
Old 03-30-2018, 08:14 PM
bigal51's Avatar
bigal51
bigal51 is offline
Cool
FWIW Was told by 2 dealers svc depts the employees all use petroleum based oil, not synthetic.
Old 03-31-2018, 10:56 AM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is offline
Sponsor
Received 1,628 Likes on 1,176 Posts
I have tried a LOT of oils in my testing over the years..... as a rule dino oils are always quieter than syn. The best I've tried is Spectro 25-60 dino, the worst is Mobil 1 V-Twin.
This is only in regards to engine noise... I'm sure M1 is a fine oil.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 04-01-2018, 06:09 AM
y22c's Avatar
y22c
y22c is offline
I have been using Spectro 25W60 for the 40K miles in 2 Harleys, love it.
Great oil pressure and engine is quieter.
Zero oil consumption in both bikes 2001, FXDX (TC88) and a 2012 FKHX (103)
Change every 5K
Ken
ROCKOUT Rocker Products (04-01-2018)
damerleball
39
12-26-2021 09:29 AM
NugBa
Milwaukee Eight (M8)
60
02-13-2018 02:41 PM
serge627
08-03-2012 11:10 AM
Mud Cut
03-22-2010 04:02 AM
Skippy60
05-30-2009 11:20 AM
Quick Reply: Dino vs Synth with M8?
