2006 Street Bob Drain Plugs
I am thinking about buying 3 new drain Plugs and painting them each a different color.
Engine oil drain - Red (P/N 60328-9B
Transmission drain - Yellow (P/N 60328-9B)
Primary drain - Blue (P/N 45893-99)
Every time I do an oil change I can't remember with plug goes to which. I have pictures that I have taken to guide the way. I think this would be an easier way to remember. I keep telling myself that when I do my next oil change I should just paint them then. But I am always in a hurry and don't want to wait for the paint to dry. This way I will have 2 sets that I can interchange when I change the oil.
Wish they made a kit like this one
Make sense or am I an idiot?
sjoko (03-20-2022)
It doesn't do to service your bike in a hurry! Take your time and check your work with your FSM. If you paint your drain plugs how will you know what each colour means?!
Well, it doesn`t make sense...
This is an oil change we are talking about, not rocket science...Pull the plugs, drain the lube, reinstall the plugs...
Note: your part number callout is incorrect, all 3 drain plugs are the same P/N: 60328-9B.
45893-99 is a pipe plug not intended to be removed, leave it alone.
How do you keep track of your valve stem caps so you don`t mix them up?
