when to change the primary oil?
I'm a newbie with my first 2016 fat boy s. i had the hd do the first 1000 maintenance and decided to change my engine oil which i did but my question is when should u change the primary and the trans oil?
thanks in advance
thanks in advance
change it as often as you like. Oil, no matter what you choose to fill the primary with is relatively cheap and it is literally right there in front of you and easy to do. Certainly won't hurt anything to change it as often as your motor oil.
NO sh*t Sherlock I don't have the manual at hand that's why I'm asking if you can't give advice then don't bother typing or clicking .
Rude ***
Rude ***
Edit: FWIW, my 2012 103
Motor Oil & Filter: 5K Miles or 1 year, whichever 1st
Note: do not overfill. fill 1/2-between full and add hot
Primary: 10K
Note: fill to bottom of clutch pack
Transmission: 20K
also, Owners Manusl: https://serviceinfo.harley-davidson....cle/lookupForm
