Jagg oil cooler fan control switch question
Yeah, they do stay cooler than I thought as well. You did say that it works when you jumper it, so whatever it is, it is not a voltage issue. Simple thermal switch, simple contact closure. There really isn't anything magical going on there, CanBUS or not. Is it possible you somehow put it in the wrong port? I don' t even know if that's possible, but I'm grasping.
it was put into the right port and everything was do as per instructions . Jagg tech is even stumped as to why it wont work, he said he thinks I have what they call a Wednesday bike meaning in his words it just runs right and is not getting as hot as I think it is I ended up wiring a toggle switch up for it. and just going to run it that way where the cooler is mounted I can easily reach it so when fell it and it is hot will turn fan on..
robbyville
09-09-2015 06:52 PM
