Mix Dexron III and Formula Plus
2013 FLSTC
I recently changed my primary fluid to Dexron III and want to go back to Formula +. Do I need to remove the cover and wash all the ATF out. Or, can I drain the ATF and fill with F+. Just wondering how well they would mix with the few ounces of ATF residual.
2013 FLSTC
Peter Carreiro (10-14-2018)
I've gone back and forth between ATF and Formula+ a couple of times without flushing. Zero problems so far through 45K miles. I don't think flushing is necessary.
i have used the HD primary oil, atf type f, 10w30 motor oil, 10w40 motor oil, 20w50 harley dino oil, and 20w50 generic racing oil in my primary. over 100k miles and still running the OE clutch plates and primary chain. never rinsed the primary, i just used whatever i had laying around the garage.
Any automotive engine or trans oil, or any mixture of the two. But whatever you do, don't use what Harley specifies....
