Oil Archive (no new posts) An archive of oil related questions and comments.
Disastrous oil change
Old 10-28-2018, 07:50 PM
Francis Arsenault's Avatar
Francis Arsenault
Francis Arsenault is offline
2nd Gear
Smile
Originally Posted by QC
On the bright side, you got a good look at what was on the inside of your filter!
You're right! That's one good news
Old 10-28-2018, 08:07 PM
Francis Arsenault
2nd Gear
Thank you guys, a lot of good ideas here.
I did try something similar to Yankee Dog and Uncle Larry's answer with one big screw driver but it didn't budge at all and the chisel method got be a little bit anxious, I was afraid to perforate the piece of motor holding the filter. I was able to remove the regulator which gave me a another small access to the side of the filter.
I like cdonis idea, I will try tomorrow to find what I need. I might have a little bit of the filter left to drill 2 screws in it, maybe through the wrench, anyone ever tried it? I saw the video below on YouTube today, I guess it might work.
robarosa's Avatar
robarosa
robarosa is offline
If all else fails, make something like cdonis mentioned with a shank to fit an impact drill. Impact will do it without any damage to your bike.
Funny stuff with these guys.
Old 10-29-2018, 09:19 PM
Francis Arsenault
2nd Gear
Finally, I did it. I did find 3 bolts that would fit the filter holes but nothing hard enough so the three of them would turn together. The bolts were too loose for the filter to budge. So I decided to drill two holes on the side of my HD wrench and then I put two small screws through the wrench and what was left of filter, small enough so they wouldn't touch the oil filter adapter, i.e. the hollow screw. I was then able to put some force on the wrench and have the filter move just a bit. After a few try it finally detached from the adapter and I was able to complete my oil change! Oh! and I made sure of applying oil to the gasket and not tighten the filter too much! The head of the screws did scratch the paint on the motor a little bit but nothing to worry about for now.
Thank you guys for the excellent ideas.
The following 3 users liked this post by Francis Arsenault:
A1A (06-07-2021), s-glide76 (08-05-2021), Uncle Larry (10-30-2018)
Old 10-30-2018, 03:42 AM
Bama Lee's Avatar
Bama Lee
Bama Lee is offline
Received 1,536 Likes on 677 Posts
Now, go smack the "mechanic" that installed it !
Old 10-30-2018, 06:11 AM
blackxpress's Avatar
blackxpress
blackxpress is offline
Amen. You’d think someone who works on Harleys for a living would at least know how to do an oil change.
Old 06-07-2021, 04:29 PM
crebo555's Avatar
crebo555
crebo555 is offline
this is how i did it today on a high mileage 98 fatboy I purchased as a project. I have all the correct tools and none of them worked. been wrenching on bikes for 30 years and this was the toughest i've ever come across....
ended up drilling 2 holes in a filter tool and inserted big screws finally got that sucker loose and oil change done.
bpav16 (06-24-2021)
Old 06-07-2021, 05:05 PM
WP50's Avatar
WP50
WP50 is offline
Received 1,694 Likes on 1,150 Posts
There have been a few times I thought about having the oil change done by a shop.
This thread reminds me why only I do it
What a mess Glad ya got it done
WP
Vec (06-07-2021)
Old 06-08-2021, 05:45 AM
Cap77's Avatar
Cap77
Cap77 is offline
Received 4,803 Likes on 2,139 Posts
Amazon Amazon
..l.t.a.
cmosentine
04-21-2016 05:13 AM
sledhead140
09-22-2008 07:28 AM
John3:16
04-24-2007 02:53 AM
bigheadted
04-06-2007 10:41 AM
00glider
27
07-06-2006 01:47 AM
Quick Reply: Disastrous oil change
