Oil Archive (no new posts) An archive of oil related questions and comments.
Mobil 1 primary/gear
Old 02-13-2019, 08:38 AM
470004's Avatar
470004
470004 is offline
Received 15,043 Likes on 6,219 Posts
The following 2 users liked this post by 470004:
lightweight bob (02-18-2019), southerncannuck (08-01-2019)
Old 02-15-2019, 01:23 AM
2018 lowrider M8's Avatar
2018 lowrider M8
2018 lowrider M8 is offline
Originally Posted by 47000412
Nice stuff this
The following 2 users liked this post by 2018 lowrider M8:
Old 02-15-2019, 07:39 AM
86glider's Avatar
86glider
86glider is offline
I use B&M trick shift tranny fluid in my primary, works great.
Old 02-16-2019, 08:30 AM
1340hog's Avatar
1340hog
1340hog is offline
I use mobile 1, 4t 10-40 racing in my primary. Never have any metal on drain plug, never a clutch slip. Been using this stuff for years in several different bikes with out any issues.
Old 02-16-2019, 09:12 AM
rivertrash's Avatar
rivertrash
rivertrash is offline
I saw Bel Ray transmission oil mentioned above and thought I would throw my two cents in. I did an ape hanger mod to my 2010 HD Road King Classic last year from Hill Country Cycles, TX. Included in the handle bar change out I upgraded to a new stainless, braided clutch cable. HCC included a bottle of the Bel Ray trani oil for the swap. What a huge difference it made to the performance and sound of the bike. Very smooth, very quite after the change. I probably would have never tried it otherwise but I’m a believer now.
Old 02-17-2019, 05:54 AM
wagsrk08's Avatar
wagsrk08
wagsrk08 is offline
Originally Posted by Jmc543
Mobil 1 in the primary. Anyone doing this?
I used Mobil 1 20W-50 V-Twin Fully Synthetic engine oil in my 2008 FLHR primary for over 48,000 miles (8 years) with no issues until I went with a Stage 2 up-grade. Then switched to Spectro Primary fluid. Now only use Spectro products in primary & transmission (6-speed Platinum 75W-140).
Old 02-18-2019, 12:11 PM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,482 Likes on 1,541 Posts
I've been using Mobil V-Twin 20-50 in my engine and primary for many years with no problems. Redline heavy shockproof in trans. My new tri-glide i stuck with F+ in the primary,, no real reason.
Old 07-13-2019, 09:11 AM
B Bop's Avatar
B Bop
B Bop is offline
Just did clutch kit, ALTO Carbonite, lifetime warranty this kit included extra fiber plate and steel plate. Increased spring pressure adding Harley Police spring "pink dot" this spring provided 19% more pressure than stock "yellow dot". After many searches, reviews & testimonies selected Mobil 1 Synthetic ATF in primary.
The primary runs quiet, cooler by 42 degrees ambient temperature (morning 76, late afternoon 93 degrees, shifting is smoother, can feel clutch grab 30% more, and finding Neutral is spot on every time.
Little over 500 miles 35% city traffic 65% country mountains tight turns and I'm very content. Will report back after 25k on clutch to give more accurate assessment.
B Bop
2012 FLHR (Road King) Stage II Red Ember Sunglo/Merlo Sunglo, Original HD Chrome Laced Profile Aluminum Spoke Tubeless Rims, ABS, Cruise Control, Security Package, Saddlebag LED Spoiler lights, and array of nostalgic & performance accessories that enhances appearance & blood curdling performance.
Old 07-13-2019, 09:32 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,541 Likes on 3,793 Posts
The engineers say do not use High detergent in a non-filtered box. If you go the recommended maintenance schedule, you want the junk to settle to the nooks and crannies in the bottom.
Even Harley went back to the first choice to a non-detergent without EP additives for transmission and transmission.
Probably really does not matter unless you really plan on wearing it out with a whole lot of a bike being your main driver and not a hobby. Few due.
Old 07-16-2019, 05:57 PM
71on72's Avatar
71on72
71on72 is offline
Received 16,317 Likes on 8,538 Posts
This in the primary. Used in motocross bikes for years. Safe for wet clutches.
https://mobiloil.com/en/motor-oils/m...motorcycle-oil
Quick Reply: Mobil 1 primary/gear
