Oil Archive (no new posts) An archive of oil related questions and comments.
Cracked housing
Old 04-26-2019, 06:28 AM
timmyh's Avatar
timmyh
timmyh is offline
Stage II
Unhappy Cracked housing
Last fall I picked up an '03 Sportster 1200 Anniv Edition from a private seller. Checked it over and did not see any signs of leaks. He seemed like a good guy... Only got to ride a couple of times before the snow flew. Then I noticed a couple of small oil drips on the garage under the oil filter after warming it up, but no noticeable loss of oil and the leak always seemed to stop after cool-down. Thought I'd address it this spring before I started riding and tried tightening the oil pressure switch, which is where it was dripping from. This made the leak worse. So I took the switch out, and since it was working fine I applied some teflon tape to the threads and put it back in thinking it would stop the leak. Again, it made it worse. I figured I needed to change the oil and filter anyway, so replaced both including a new K&N filter and picked up a new switch from a dealer. Buttoned it all back up and fired it up. Still leaking. Now the leak seemed to be coming out from around the filter gasket at the very bottom. I removed the filter and fiddled with the gasket to make sure it was seated correctly and lubed - that's when I noticed a hairline crack running from the milled surface of the housing back to the pressure switch outlet. Full thickness. I'm guessing there was a small crack and torquing the switch to take it out and put it back in a couple of times may have widened it. It still only leaks under pressure while the engine is running, but significantly more now - a steady drip. I have to do something about it (I probably could have left it alone and just cleaned up the couple of drops on the floor every now and then). After checking out a couple of youtube videos extolling the virtues of jb weld it seemed like that might work, but there really is no way to cover the inside or along the milled surface or outlet threads. So I was thinking maybe massage some high temperature silicone gasket seal into the crack across all surfaces. It would take the heat and remain flexible. Might not stop the leak altogether, but at least slow it enough to live with. Any recommendations???
Old 04-26-2019, 07:59 AM
bustert's Avatar
bustert
bustert is offline
band-aides fail. the crack can continue especially so if the crack is not stress relieved.
two options would be to remove the cover and have it repaired or buy a second hand cover and swap it out. always can repair the old one for the shelf or sell it.
Old 05-01-2019, 08:51 PM
langwilliams's Avatar
langwilliams
langwilliams is offline
I had a engine case crack in a Honda sport bike an I had a mobile welder come out an tig it. did the job.
Old 05-13-2019, 01:03 PM
timmyh's Avatar
timmyh
timmyh is offline
Stage II
Default Thanks!
Thanks, I appreciate it.
flhsport
EVO
08-14-2016 05:46 AM
Theakerr
10-26-2011 11:03 PM
stevevfd
10-30-2008 03:14 PM
Gmansitur
06-28-2007 05:42 AM
mopar_smbv8
04-30-2007 10:39 AM
Quick Reply: Cracked housing
