Fatboy Oil Change
Fatboy Oil Change
Hey guys
I just got an '03 Fatboy, and as it's my first Harley-Davidson, I'm a newbie. \\; I decided today I'm going to change the oil with Amsoil 20w-50. \\; The owners manual says only to drain the oil tank and change the filter, and you're done. \\; However, I see two more drain plugs (allen head) that appear to be for the crankcase. \\; Do I drain these as well? \\; I know, I know, I need to get a service manual. \\; Should I get a factory one, or does somebody like Clymer make a good one for the TC88 Fatboy? Or both?
Thanks, Mark \\;
Thanks, Mark \\;
RE: Fatboy Oil Change
You have 3 sumps on your bike. Engine, Trans, primary chaincase.
You want to run the 20w50 in your engine and primary and get some Amsoil 75w90 or 75w110 SVG gear oil for your trans.
Change the engine &\\; primary at 5000 miles or 1 year
Change the trans at 15,000 miles or 2 years
You will like the amsoil very much.
But do get a factory service manual. It will save you big $$ and show you the way to do everything. You can get on from Zanotti's HD on line or for about $60 at you dealer. Zanotti's is a few bucks cheaper.
thrillseeker
06-16-2008 02:22 PM
