Help!! Oil Drain Plug
RE: Help!! Oil Drain Plug
Just to make sure we are clear here.......on mine there is a recessed Allen head plug right next to the Oil Drain Plug....you aren't trying to loosen that one are ya?
ORIGINAL: Hooper
I bent and broke all my allen wrenches and allen sockets. The plug will not budge. Any suggestions on getting it out?
Jeff
I hope you're not referring to the plug pictured here with the allen wrench in it. The drain you need is the one in the background here behind the one with the wrench in it. That one you are trying to remove has red locktite on it and needs to be heated up should it have to be removed like for an oil temp sending unit to be installed.
Maybe these pics might help, the first is a view from the top where drain hose connects to plug and the second is a close up of what the plug looks like. This is on my Fatboy, not sure if it's the same as your bike. Notice it has a recessed allen with a hex head on the outside, you should be able to use either an allen key or a socket. Hope this helps.
