Oil Archive (no new posts) An archive of oil related questions and comments.
oil change funnel
Old 04-21-2006, 06:53 PM
dakotacrk's Avatar
dakotacrk
dakotacrk is offline
Default oil change funnel
What do you clean a oil change funnel with after a oil change?
Old 04-21-2006, 07:49 PM
oldgeezer's Avatar
oldgeezer
oldgeezer is offline
Default RE: oil change funnel
Either gasoline or varsol, which ever I have handy at the time.
Old 04-21-2006, 08:18 PM
Cessna172's Avatar
Cessna172
Cessna172 is offline
Clean the funnel? Just use gravity into a container.
[sm=icon_cheers.gif]
Old 04-21-2006, 08:38 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
ORIGINAL: Cessna172
What he said....
Old 04-22-2006, 01:22 AM
2mean2like's Avatar
2mean2like
2mean2like is offline
What I like to use is dish soap (Dawn works real good) and water.
Also good for any oil spilled from changing the filter
Old 04-22-2006, 02:06 AM
IRready's Avatar
IRready
IRready is offline
I let it drip dry then put a clean rag in it. Just wipe it clean before next use. SOAP and WATER??????? Geesh.......
Old 04-22-2006, 02:35 AM
2mean2like's Avatar
2mean2like
Yes, cleaning the funnel is extreme (****), but I prefer a clean funnel when I pour in new oil into my bike. Not from
a funnel that has accumulated dust and dirt from the garage.
Old 04-23-2006, 12:02 AM
bagga's Avatar
bagga
bagga is offline
i wipe mine out with a rag, when i store the funnel it goes on the shelf up side down with the rag layed over the spout.
Old 04-23-2006, 02:32 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
I only use a 52100 stainless steel funnel once then discard the soiled one. The new funnels I purchase are stored in a locked humidity and temperature controlled class100 clean room vault until ready for use. Any oil spilled on the floor of my garage is immediately removed with a 300F degree muratic acid wash and dried with a flame thrower and the exhaust gas from a General Electric CFM56 gas turbine engine that I converted into a leaf blower. I'm very serious about keeping the dirt away from my engine.
Old 04-23-2006, 07:05 AM
billnourse's Avatar
billnourse
billnourse is offline
Spray it with a little brake cleaner. Removes all the oil residue, and then the brake cleaner evaporates and leaves no residue.
Regards,
Bill
Quick Reply: oil change funnel
