Oil Archive (no new posts) An archive of oil related questions and comments.
Fork Oil Capacities All Years and Models
Old 11-27-2017, 07:57 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Wink
No ounces per tube...
All of the oil reservoirs on our bikes have levels, to which they should be filled. The quantities or fluid ounces in the manuals are only a guide - in other words have this amount to hand before you start.
Old 04-14-2018, 05:08 AM
Wrencherfromwayback's Avatar
Wrencherfromwayback
Wrencherfromwayback is offline
1st Gear
First timer asking question here. I don't see anybody stating proper orientation of forks while checking oil level. Installed and at an angle or removed and basically vertical? Impression I get from the manual is that they would be removed during this service. also according to 2012 FLHTK manual, lower leg should be pushed up all the way on the tube when using depth gauge with syringe , but again i don't see any one here stating that?
Old 04-14-2018, 02:05 PM
grbrown's Avatar
grbrown
grbrown is offline
Doesn't make any difference, as far as fork legs are concerned. When tipping them over at the stock angle, the mean level of the fluid is going to be the same as if they were vertical. Also the diameter of the forks is small enough that as long as both levels are the same any difference compared with measuring them when vertical is going to be negligible.
Old 08-02-2023, 01:22 AM
abcuros's Avatar
abcuros
abcuros is offline
Stage II
You're right. The viscosity of fork oil can significantly impact the suspension's performance. It's generally best to stick to manufacturer recommendations or experiment with minor changes. 20W and 30W could indeed be too high for many models, potentially causing a harsh ride. Always refer to your specific bike's manual for accurate specifications.
grbrown (08-02-2023)
Old 08-02-2023, 03:05 AM
M Oclaf's Avatar
M Oclaf
M Oclaf is offline
Received 5,689 Likes on 2,616 Posts
Old 08-14-2023, 01:57 AM
Ddjjss's Avatar
Ddjjss
Ddjjss is offline
6th Gear
Default Fork oil
Better check those weights of lube again your a bit high
good luck with 30 weight in a front fork. even 20 is pushing it.
I have a 2002 heritage classic I use 20 weight with 1000 miles on the oil, and it bounces very easily just pushing down on it
Old 08-14-2023, 03:12 AM
Goose_NC's Avatar
Goose_NC
Goose_NC is offline
Received 4,208 Likes on 1,968 Posts
Originally Posted by skycrane
I searched the internet for this info and found there wasn't anything out there. Most of us don't have a harley manual anymore!
*snip* .
Why wouldn't someone buy a manual for a vehicle they own and desire to work on? Even the cost of new manuals is less than 3 shop hours.
Ebay and Facebook market place is where I've found OEM manuals. Sometimes mmfoubd manuals on DVD that are searchable.
sgillikin
03-03-2013 08:27 PM
Steel Steed
07-09-2012 06:59 AM
warbisjohn
04-24-2011 08:35 PM
DR. V-TWIN
03-15-2011 07:51 PM
IU_Booger
08-07-2005 02:37 PM
Quick Reply: Fork Oil Capacities All Years and Models
