Oil Archive (no new posts) An archive of oil related questions and comments.
Flushing Out Lockhart Oil Cooler
Old 12-30-2009, 06:50 PM
Outdoor Bob's Avatar
Outdoor Bob
Outdoor Bob is offline
Stage I
Default Flushing Out Lockhart Oil Cooler
I need to cleanout my lockhart oil cooler of metal shaving from a bearing gone bad and it has an internal thermostat. Any ideas for flushing the cooler out before returning it to surface on the rebuilt engine? Thanks for any help.
Bob
Old 12-30-2009, 10:25 PM
nocarb's Avatar
nocarb
nocarb is offline
Bob
Disconnect hoses and blow out with air. Wouldn't hurt to do a 50 mile oil change also.
Old 12-30-2009, 11:22 PM
Razerman's Avatar
Razerman
Razerman is offline
Remove the cooler from the bike and disassemble as much as you can (fittings, clamps,hoses ect.)
go find a auto repair shop to use the stoddard solvent parts cleaning tank. the stoddard solvent will break down the oil and allow you to rinse out the chips,shavings stuck to the oil in the cooler passages. If you can't remove the thermostat you can get a pot of hot water, (Hot enough to open the thermostat) place the cooler in the hot water and use something to grip it and swirl it around to break free any remaining pieces then before it cools down,(and thermostat re-closes) blow compressed air through the tubes to complete the job. that's just me, good luck explaining to the old lady why you want to borrow her canning kettle.
R.
Old 12-31-2009, 06:04 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,467 Likes on 4,598 Posts
I`ll tell you what we do when an aircraft engine puts metal shavings into the oil system, we send it out to be disassembled and physically cleaned out just like the old radiator shops used to do.
You will never get all the debris out, at least thats the way it was taught to me in airframe and powerplant school. I would sooner run without a cooler than one that has gone through an engine failure.
Old 01-01-2010, 12:16 AM
1skrewsloose's Avatar
1skrewsloose
1skrewsloose is offline
I would say to be on the safe side, replace the oil cooler, why take chances when that much money, time and effort is involved.
Old 01-01-2010, 12:58 AM
Inspector 12's Avatar
Inspector 12
Inspector 12 is offline
Old 01-01-2010, 03:00 AM
VibratingPotato's Avatar
VibratingPotato
VibratingPotato is offline
Just like Razerman and Dan89FLSTC said.
Clean the crap out of it, all spotless n stuff.
Then buy a new one like 1skrewsloose said.
Then send the old one to me so I can put it on my scoot.
LOL just kiddin...(not really)...LOL
If you can tear it down far enough to get the crap out of it I would use it.
Then like nocarb said, an early oil change wouldn't hurt.
Beer me
Old 01-01-2010, 07:05 AM
el chivito76's Avatar
el chivito76
el chivito76 is offline
As a mechanic of 10 plus years i have rebuilt a few engines. That said any engine that was rebuilt that had an oil cooler got a new one. Dont even mess around for what it costs,
89Speedy
02-13-2022 02:17 AM
FastHoss
11-07-2010 04:41 PM
BDHABT
04-01-2009 09:04 PM
spiritwarrior
04-15-2008 07:13 PM
wjl24
09-10-2005 03:26 PM
Quick Reply: Flushing Out Lockhart Oil Cooler
