View Poll Results: A poll
Voters: 5286. You may not vote on this poll
What TRANS oil do you use?
#402
Thoughts about using a 15w-50 synthetic oil in a 2009 6 speed transmission? Kinda like a jungle with scattered info. Some say GL-5 rated oils (75w-90/140)are not neccessary and maybe too much. Amsoil is the only company I see that rates their 20w-50 m/c oil as GL-1. Mobile says the 20w-50 m/c M1 syn is better than their 75w-90 gear lube, as does Amsoil. Lastly, the viscosity chart would show a 15w-50 oil actually closer in spec to a 75w-90 gear oil than a 20w-50 oil. Reason is I can get a qt of M1 15w-50 for $5 from a buddy. Heck, I'm sure it would be just fine but just throwing out for opinions...
http://www.teamrip.com/viscosity_chart.html
#403
I switched to Amsoil 20w50 at 3200 miles. 5000 mile is coming due so Ill do 20w50 in two holes and try Amsoil 75w90 in tranny. I believe in the porduct an dwill do just fine. A lot of mix reviews and I respect everyones opinions. Its all a matter of choice an dwhat works for you and the bike. Ride on and hard.
#406
Hey all, new to the site and to harleys,
Going to do my first service on my 08 rocker c,bought it used and it is due for the 10,000 mile service.
Was going to run 20/50 amsoil in all three holes but after reading on here it looks like most people are using gear oil in the tranny.
Does anyone know if this is recommended by the factory or will it void a extended warranty?
Thanks,Daniel
Thanks,Daniel
#407
Thanks,Daniel
Thanks,Daniel
#409
Thanks for the replies,called the dealer and they said amsoil is ok,they were going to check out using gear oil in the trans,still waiting lol. Going to give them a call again tomorrow.
