Same oil for crankcase and transmission?
Hello, i own a HD SPORTSTER XL1200L, 2006, and i want to change the oil, it s my first motorcycle and i really don t know exactly the correct oil for use in the crankcase and transmission ,primary ,, i bought formula plus oil, and i want to inow if i can use it for the crank case, transmission and primary? Or i have to get another one for crankcase?... Thanks
Formula+ is for the tranny/primary. One fill as they share the same fluid.
Formula+ is NOT for the engine! One qt. (32 oz.) 20W50 (whatever brand you want) for the engine. 3 qts. plus a filter. Best to buy a service manual as it sounds like you might be new and guessing. Good luck and there are Youtube videos that will help you. |
Your bike has two separate oil systems because they each use a different type of oil. An alternative to the service manual is the owners manual, which will answer that question. A dealer can supply either although the service manual is the most useful. You can download an owners manual on the H-D website - go to the Owners tab.
Before going any further also read the Stickies at the top of this Oil section. |
© 2024 MH Sub I, LLC dba Internet Brands
