removal & replace distributor
10-20-2016, 02:33 PM
i have a 50 pan. at the risk of sounding stupid i have never removed and replaced a distributor. i did a top end rebuild and i want to change from 6 v to 12 v.
can i not just remove existing dist. with new one without having to retime the motor? can anybody help?
10-20-2016, 06:10 PM
the original dizzy is neutral with voltage as it does not matter to the points / condenser
the ignition coil is the only thing you need to change in the ignition system
AND the dizzy wont come out with out taking the front head off
No question is considered stupid on this site
10-20-2016, 06:29 PM
thx for your help!so just change out the coil,bulbs. what about the gen? i dont know if its 2 or 3 brush. it has a solid state regulator
10-21-2016, 07:39 AM
you asked about the dizzy - if your converting an original 50 pan to make it the bike worth less in the end, and its original only once
every thing 6 volt needs to be 12 volt < what a shame 66 years as it was and now its being carved up
jrotis215
Electrical/Lighting/Alarm
05-24-2018 08:26 AM
ratz
04-03-2013 04:43 AM
Benedetto
EVO
15
09-20-2011 12:16 PM
dex0807
EVO
09-29-2008 02:15 PM
riden2low
04-17-2008 09:40 AM
