shovelhead flywheel
shovel wheels
I see the crank pin (supporting the rods ) should work thru the early shovels as far as the pinion and the old style crank shaft maybe ? If you get the wheels for free try it I take it you have the 74 CI jugs on this bike ? My 46 knuck had 61 wheels with 74 jugs Talk about low compression I used to start it with my right arm (back in the day way back ) in 1990 I put 80 CI S&S wheel assembly in What a difference in power I don't ride that rigid knuck very much any more Good luck on this project
shovel wheels
On second thought don't do it ! buy a complete flywheel assembly for the 74 project and don't forget to clear the rear cylinder scraper plate The 61 wheels are 1/8 in less in diameter With those shovel wheels you are looking at things like shaft tapers might vary V- twin P/N 10-1007 should work or look at S&S or others
Fatbob usmc EOD
07-24-2013 06:30 PM
assembly, compression, crankshaft, diameter, evo, flywheel, flywheels, harley, head, low, rods, sale, shovel, shovelhead, work
