Energy One Extra Plate Clutch Kits
Get rid of the failure-prone riveted clutch plate found in your Harley's stock drive system with an Energy One Extra Clutch Plate & Spring kit from PartsGiant.com.
These model-specific clutch kits come with the requisite number of aramidic fiber friction plates on aluminum cores, steel separator plates and either, zero-crush springs or a diaphragm type clutch spring. Upon installation of this clutch kit, you simply discard the stock rivet plate (aka grenade plate) for piece of mind. About the only downside to eliminating the rivet plate is that the clutch lever's friction zone will be a bit narrower and, for those with particularly sensitive ears, the clutch might sound a little louder. Still, that's a small price to pay in order to ride around knowing that you won't find metal from a failing rivet plate in the oil during your next oil change!
Speaking of oil, these clutch kits can be run wet or dry and are compatible with your preferred motorcycle-specific oil.
Available for most 1980 and up Harley-Davidson motorcycles, give us a call to order yours today!
__________________
Contact us for discounts exclusive to HDForum members. Some exclusions apply.
Email: forums@partsgiant.com
Phone: 888-575-6570 ext 817
www.partsgiant.com
www.partsgiant.com
