Parts Giant Giant selection of Harley Davidson aftermarket parts from exhausts to filters. Contact us for discounts exclusive to HDForum members.
S&S 89cc Super Stock Cylinder Heads
Old 06-22-2018, 09:25 AM
Parts Giant's Avatar
Parts Giant
Parts Giant is online now
Platinum Sponsor
Default S&S 89cc Super Stock Cylinder Heads
S&S 89cc Super Stock Cylinder Heads work well with engines of stock displacement, but are ideal for somewhat larger stroker or big bore engines up to 110".
89cc combustion chambers provide a compression ratio that's slightly higher than stock, but still manageable.
Larger intake and exhaust valves maintain port velocity for good low and midrange response, but supply enough air for bigger engines to perform to their full potential. On stock Twin Cam models, the intake ports flow 182 cubic feet per minute while the 89cc heads deliver 264 cubic feet of air every minute. This, combined with the increased compression, provides for a reliable boost in power. And the included S&S high-performance valve springs allow the installation of camshafts with up to .650" lift, though you can certainly use your stock cams, too.
For 2006 and up models, each set of heads is compatible with stock rocker boxes, exhaust, and intake manifold to greatly simplify installation. Earlier Twin Cam engines, when using stock pistons, will require valve pockets to be machined into the pistons as the larger valves need the extra room.
Available in black or silver, and made in America - you can see all of the details for these awesome heads on our website by following this link. And of course, when you're ready to order, give us a click or call to get a set of these awesome heads on their way to you, fast!
__________________
Contact us for discounts exclusive to HDForum members. Some exclusions apply.
Email: forums@partsgiant.com
Phone: 888-575-6570 ext 817
www.partsgiant.com
txphatboy
Engine Mechanical Topics
13
05-30-2021 04:20 PM
Butts05Train
03-12-2020 08:49 PM
Rusty Axle
Shovelhead
11-30-2017 04:01 PM
skruzluce
Exhaust System Topics
11-08-2009 04:31 PM
Tltrump
11-05-2006 03:28 AM
Quick Reply: S&S 89cc Super Stock Cylinder Heads
