Cobra True Duals Header Pipes
Ride to the oomph of a different tune with a set of Cobra True Duals header pipes on your 1995-2006 FL Touring model.
Each primary header is equipped with a one-piece heat shield for a smooth look that also eases the difficultly sometimes associated with lining up multi-piece heat shields.
Header diameter is 1-3/4" from tip to tail and you can match 'em up with just about any aftermarket mufflers that fit the stock headpipes on all 1995-2006 FL Touring models. This alone provides a lot of build flexibility!
And, of course, to get the most out of your updated exhaust configuration, you'll want to add a Cobra Fi2000R (for fuel-injected machines) or a Cobra jet kit to your order. Each of those tuning components, like the headers themselves, come with all required installation hardware and easy-to-understand instructions. It makes installing everything a rather straight-forward operation that can usually be completed in a few hours by a novice mechanic using simple hand tools. If you're comfortable doing an oil change, exhaust components will be no problem!
In stock and ready to ship, call or visit the website, today!
__________________
Contact us for discounts exclusive to HDForum members. Some exclusions apply.
Email: forums@partsgiant.com
Phone: 888-575-6570 ext 817
www.partsgiant.com
www.partsgiant.com
nocoast
Touring Parts
11-20-2017 11:29 AM
