Progressive Drop-In Fork Lowering Kit
Be it looks or comfort, a Progressive Fork Lowering Kit is the simplest way to bring the front end of your machine closer to the ground. But, because it’s a Progressive kit, you won’t have to worry about bottoming thanks to the progressive spring rate design. The springs allow for a soft feel while cruising along and progressively provide greater resistance as the forks compress. The result is a smooth ride without compromise.
Each kit comes with easy-to-follow instructions and all the suspension components you’ll need to get the job done. Each set of springs will lower the front end of your bike up to two inches. Available to fit a wide range of Harley-Davidson motorcycles, you can read more about these fork springs on our website here. And of course, any questions at all can be answered by our expert staff by calling 888.575.6570, PM-ing us here, or just send a note to forums@partsgiant.com with PROGRESSIVE FORK LOWERING KIT for HD in the subject line, along with the machine you’re riding by model and year, and we’ll get back to you right away! https://cimg1.ibsrv.net/gimg/www.hdf...a452e5381f.png |
© 2024 MH Sub I, LLC dba Internet Brands
