Magnum Ape Hanger Handlebar Installation Kits
Magnum Ape Hanger Kits
Are you adding some ape hangers to your Harley and having a hard time finding the right control cables, brake lines and wire harness extensions to go with it?
Magnum Shielding has the answer for you! Available for a range of Harley-Davidson motorcycles with, or without ABS brake lines, each kit includes everything you need to get the job done in one complete kit.
You get brake lines, (upper and lower where required), clutch cable, throttle cable, idle cable and wire harness extension cables that are all spec’d out for your new handlebar rise in one box. The quality of these American-made components cannot be understated; everything is well made so as to not only look good, but perform better than the stock controls you’re replacing.
Available for a range of ape hanger configurations, you can view these cable kits on our website here and then call us on 888.575.6570, send an email to forums@partsgiant.com PM us right here; however you do it, please be sure to let us know exactly what machine it is that you’re riding by make, year, and model so we can get you set up right!
__________________
Contact us for discounts exclusive to HDForum members. Some exclusions apply.
Email: forums@partsgiant.com
Phone: 888-575-6570 ext 817
www.partsgiant.com
www.partsgiant.com
