Parts Giant Giant selection of Harley Davidson aftermarket parts from exhausts to filters. Contact us for discounts exclusive to HDForum members.
Energy One Clutches Clutch Plate and Spring Kit
Old 07-16-2019, 09:30 AM
Parts Giant's Avatar
Parts Giant
Parts Giant is online now
Platinum Sponsor
Default Energy One Clutches Clutch Plate and Spring Kit
US-made performance clutch components for your Harley-Davidson from Energy 1 Clutches. When you pull the components out of the box, you notice right away the quality and care that went into assembling each part.
Depending on the application, friction plates use either a tempered steel or aluminum core on which Energy 1’s friction material is bonded to. You get positive clutch feel, progressive grip at the lever and sure-footed grip when you open the throttle.
Steel separator plates are precisely cut and flat to eliminate juddering and the clutch spring(s) itself is made to be slightly stronger than stock for added clutch life.
Each kit ships with a full set of friction plates, steel separator plates and the requisite clutch springs for the model you select from our fit guide. And there’s no mucking about with swapping plates around to get the correct clutch stack height, each kit comes to correctly matched up to OEM-recommended clutch stack height. Just soak ‘em in oil, install and hit the road!
__________________
Contact us for discounts exclusive to HDForum members. Some exclusions apply.
Email: forums@partsgiant.com
Phone: 888-575-6570 ext 817
www.partsgiant.com
zyban
12-21-2014 08:08 AM
bigmant
11-12-2014 05:38 PM
jwatkc
03-31-2014 10:43 AM
Tech23
12-07-2013 07:20 AM
steveh326
17
11-24-2011 07:57 AM
Quick Reply: Energy One Clutches Clutch Plate and Spring Kit
