Rear fender paint warranty?
Hi guys,
I have 12' XL 1200X Sportster FortyEight. Yesterday, I was cleaning it and I realized that there is rust (oxidize) at my rear fender's left side and started to flake off.
I am the second owner of the motorcycle. It is bought from HD Istanbul. But I live in Ankara/Turkey. So, can it be under warranty? Or does HD Ankara tell me "no way out".
The pictures are at the attachment.
Thank you.
Thank you.
It costs nothing to ask your dealership but I suspect you already know what their answer is going to be? Ankara as most bigger Turkish towns and cities are awash with talented car, motorcycle repair and paint shops.
On close inspection of your photographs (it could perhaps be the light) it looks like the affected area has been painted before and not very well? With it being five years old it will most certainly not have any paint warranty whatsoever, unless you were given a written warranty by the dealership you bought it from. Usually you may have been given a 'limited' three months parts and labour warranty but that will not include paint? I would simply get it stripped back a decent primer and repainted. A quick question..... Why does it look like the rear fender bolt is protruding slightly, it does not look right to me?
lordbarbaros (09-02-2017)
With it being five years old it will most certainly not have any paint warranty whatsoever, unless you were given a written warranty by the dealership you bought it from. Usually you may have been given a 'limited' three months parts and labour warranty but that will not include paint? I would simply get it stripped back a decent primer and repainted. A quick question..... Why does it look like the rear fender bolt is protruding slightly?
Sorry the photographs were misleading because of light and reflection. I too had a 48 with a side mounted number plate but the bolts had no exposed threads showing. Could it be the paint was damaged either when the side plate bracket was fitted or because it is not tight? I fitted my bracket and unless you keep all the bolts loose it can be difficult to align them if you do them up tight before fitting and final tightening of them all. Just a couple of ideas. I have attached photographs below. I think I would just get it re-sprayed locally myself?
