Sanded & Polished Lowers
Clear?
Did you shoot them with a clearcoat afterwards? That really makes a polished metal look excellent. Seals up the polished finish and keeps corrosion at bay. Also gives a nice smooth surface showcasing the shine. Helps seal out bug splats and makes the guts easier to remove in the future. .
I did the same with mine while my bike was getting repainted. There are lots of info on techniques but basically I started off with 450 grit wet, always wet, finished with 1500, then used drill-operated buffers, both cones and wheels with some Mother's. No clearcoat! That's the original problem. Harley uses clearcoat which eventually chips and looks like crap. It's been about a year and 15k miles later and they still look good.
I agree! I stripped the clear off, cleaned them up and left it as "brushed or grained" like they looked from the factory.
I agree with not using clear coat. No clear coat makes it easier to touch up the finish but it holds well without the clear coat. Wax helps also. YD
