Repurpose a tank
Repurpose a tank
I have an 81 FLT, you know the one with the GW looking tank?
Been searching for a newer style, found a dented FI from a 97 king, FI means easy access to fix the dent , but I need the pingel adapter, also need a non working fuel gauge just to plug the hole, also need the plate to cover the hole. Is the fi pump mounted to the plate? Can I make my own plate?
