Super Glue remnant remover?
NB this might remove paint too!
Get some acetone - get some cotton buds - acetone on bud - gently rub bud over SG residue, wipe with another bud.
Depending on the surface and paint, rub VERY gently or you might start to remove the paint (or try it on a tiny hidden are of paint to see if the acetone softens it)
NB - acetone evaporates in a nanosecond - pour it from the bottle into a small container (remember the old camera film canisters? Something like that)
Not much else will touch superglue.
(Try " 3M adhesive cleaner", I've read reports it's good for SG too)
Even if the paint is OK, the SG and the cleaner will mean it'll need a bit of a buff and waxing afterwards.
Received 2,858 Likes
You might try nail polish remover (methyl ethyl ketone or MEK)-very similar to acetone (dimethyl ketone) but a little less likely to hurt the paint. Try a test spot in an inconspicuous location. And smear some vaseline around the spot to minimize any possible contact of the solvent with the paint.
