2016 Carbon Crystal - PPG or Axalta paint code?
Just curious if anyone has a base coat formula number for Carbon Crystal - either PPG or Axalta (DuPont) formula number would be appreciated. The color is black with coarse white pearl or coarse metallic flake that is mostly not visible unless it's in direct sunlight.
98601EBR is the paint code, See if a paint store can cross it to a PPG Deltron or Axalta Chromabase system
I believe I have solved the mystery on this color. It's called Mystic (# 936719). PPG makes a special Glass Flake effect that's part of their Vibrance Collection called "Crystallance". There's 6 different colors in this collection and these are sprayed as a tri-coat. In this color the black base goes down first then mid coat has VM4501 silver flake in the formula. This is a PPG only color as they are the only manufactuerer that makes this Crystallance effect.
http://us.ppgrefinish.com/PPG-Refini...ss-Flake-Colle
I have a PPG formula number that was determined by the Rapid Match color camera. #938553 "Star Fire Black" was given a match number of 6, which means the color camera is relatively confident this formula will be a good color match. I have not sprayed this out yet, but I do think it will be pretty close. I'll update as I have more info.
I just went through a mess like this
I put stretched saddlebags, side covers and rear fender extension on my 2013 Chrome Yellow Pearl streetglide
do yourself a favor and buy your paint at a Harley Davidson dealership
my bodyshop guy bought paint from 3 different paint companies, none were even a close match
I bought paint from my local dealership for $143.00 a quart and it matched perfect.
Scubasrevo (12-17-2021)
