New to Powder
New to Powder
I have never done powder coating myself nor have I had it done for me in the past, so please forgive me for my ignorance in the following.
I had my fork lowers, triples and tappet blocks coated in gloss black by a local guy to me. Here is where my questions come in...
There should be a nice sharp line where it was masked off, yes? On my triples for example.. There is a jagged rough edge at the opening to the holes for the fork tubes. So much so in fact that it can be seen when the tube is slid into the triple.
Can this edge be sanded smooth? Should it be re-done?
I can post photos this evening showing exactly what I am referencing.
What do yall think?
What do yall think?
pictures are always good.
it is easily repaired, a +++ for powder. the area in ? can be repowdered and flowed out. powder does not like sharp corners and when applying powder, you have to apply from diff angles. another thing is the mask, if you use the wrong type, sometimes the adhesive will flow out when baked.
my thought is you went to a lot of trouble so why not have it the way you want, i would have it fixed. i have been down that road many times and will repair before i let it go.
easy way to hide that is to drop in some matching paint to fill in the voids.
another trick is to remove the mask when warm enough to touch without affecting the cure, it will peel away leaving a clean line. and if it were adhesive creep, since it is warm also, less chance to pull a jagged edge.
That's incredibly petty. The nature of powder coat is that it doesn't allow for crisp lines like paint. The build up is what makes it durable. sand that edge for a uniform reveal or just put your fork tube in and you'll barely notice
