ColorRite rattle cans, great paint.
Thanks,
John
I just got a can of primer/sealer from Autozone. It will be lacquer based After you get all the rust off, you can seal it right away with this primer/sealer. If you have any filling to do, also at Autozone or wherever, you can get a small tube of spot putty. You will need to block sand the area smooth, and re-primer to cover the spot putty. Make sure the spot putty is completely dry before sanding as it will shrink on you as it dries. I usually apply the spot putty and let sit overnight. There is also a product called "extend" and other brand names that stops rust. You rough sand, clean, and spray this on and you can coat over this also. I had some rust on the inside of my fender where the rear fender brace is bolted and this is how I treated it.
kre84u (01-28-2019)
not sure, never used 2K. I used to use PPG when I had a spray booth in my garage. So I am trying this ColorRite. I heard some great things. When researching rattle cans I heard that a lot of people do most of the work of sanding, prepping, and shooting the color. and take to professional shop to have the 2 K urethane coating. ColorRite shines up real nice and use a urethane. I had to let set for 3-4 days at least, then cut it with 1500 and 2000. Then used rubbing compound to shine it. I need to polish it then use McGuires swirl X then some coats of wax. Can't wax for 3-4 weeks so ok there. I am using ColorRite because a guy on Amazon sells it for half what the factory sells it for. 1 can of color and one can of clear for $40 shipped.
