Best Vivid Black paint
If you are going to do the work yourself, I would suggest ColorRite. They make a vivid black, and sprays out nice and take your time on the cut and buff and it will be better than factory. ColorRite is base coat and clear, check out my post here. I am having great results without having to build a spray booth. I just spray in the garage. I am getting remarkedly low dirt/dust specs in, and they sand right out. about 40 bucks per (2) can set of 1 color and 1 clear. check it out on Amazon.
Longbeard71 (10-09-2022)
And a good brush. Lol
Can you use and epoxy primer with the Colorrite spray can products? Can’t find anywhere their paint specs and which type of primer to use. Painting a bare fender and want to make sure I use the best primer for rust protection and also paint adhesion. Thx.
-Matt
-Matt
