Clutch stuck in 5th gear
I have a 2009 electra glide that is stuck in 5th gear, is the clutch easy to take apart and is their a place to get a parts diagram for the clutch? Thanks for any help......
Here's a start friend
http://www.shopronniesharleydavidson...partfinder.htm That's a parts fiche you can use. You'll need a shop manual and some tools. Around here, the more you help yourself, the more help you'll get. |
How do you know that it is a clutch problem?
Michelle, welcome to HDF from the UK. Before you start pulling your bike apart, tell us more! It's impossible to see how your clutch is causing your transmission to be stuck.
While sitting still with engine off, it is sometimes necessary to rock the bike with the clutch out in order to get it to change gears. I would try that first.
Originally Posted by ohioflhs
(Post 13292214)
© 2024 MH Sub I, LLC dba Internet Brands
