Sqeaking sound from primary area
So I've recently developed a loud intermittent chirping/squeaking sound coming from the primary the last day or two.
With the engine off and rolling the bike back and forth in first gear produces the squeak, too.
I pulled the primary cover off...and everything seems as it should...but the squeak sounds like its coming from behind the inner primary cover behind the clutch basket.
I'm thinking the main drive bearing is shot...do these symptoms sound familiar to anyone here?
It's an 06 dyna, btw
Been through that particular problem ... IPB replaced 10,000 km ago. Not the same symptom/sound at all.
It's a pronounced squeak that appears especially when I brake hard to a stop and will stay squeaking even in neutral standing still.
When I got home and shut the engine off, I rocked it back and forth in 1st gear and which also produced the squeak.
I'm 99.9 % sure it's the main bearing on the output shaft...I'm just checking to see if anyone else can confirm my suspicion before I take it in to a shop.
I had some tranny fluid drip down the back of the inner primary(I know its tranny cuz it's redline which is milky red)...
I was wishfully hoping it was coming out of the shifter shaft seal. now I fear the worst.
