Shift pedal not engaging
2013 Electra Glide Classic FLHTC This morning while on the way to work, I came to an intersection and went to downshift and the pedal seemed to stick. Took off and the shifter just kinda flopped around. Everything was still connected and tight it just seemed as though it wasn't engaging the (shift pawl??). Drove back home in second gear, could not change the gears at all. Any suggestions??
Thanks, I'll check it when I get home. Before I cruised at a whopping 30 mph in second gear all the way home(about 7 miles) I checked the linkage and it all appeared to be moving in the proper direction at the same time, though it may have been slipping.
EXACTLY!! Bought the lever on the way home, $42.00, and when I got home tested it thoroughly. After a few tough shifts, it began to slip. Off and on in 20 minutes....good or better than new. THANKS!!
snooter
09-17-2018 10:13 AM
