Possible IPB problem
Hi, I've got an '06 Dyna as per my sig. When I had the primary off to replace the pulley, I also replaced the IPB with the Baker unit as a preventative measure. Now just today (about 4k miles later) I heard a howl/almost grinding sound from my primary, and as I coasted to a stop, I could feel something grabbing, almost like a break. I was only a block from work, so I continued on and the problem came and went a few times. With the bike out of gear, you can feel it grab when you push the bike. If I rock it a little it releases and rolls good for a bit and then grabs again. No sound from breaks or wheel bearings. I'll tear into it tomorrow, but any advice heading into this would be much appreciated. Thanks, and have a great day.
Stych
Stych
Stych
Stych
The last one I did like this had symptoms very much like yours. If the battery light comes on, you will know but if you have a noise and a physical sensation something is hitting you need to take it apart.
