BDL closed primary drive system 94' EVO common problems?
Had the belt pop on a ride. Got all parts etc. put everything on after a short ride to check everything out I noticed a lil rubber dust on the primary cover held it in place then noticed the belt rubbed in two places. I cut out a bit of aluminum to make clearance.
Has anyone had such an issue with a BDL closed primary drive on a 1340 evo ?
I took it for a ride after trimming back the aluminum on the case. The belt was in the same position it didn't move there is probably 3/32nds space between the starter gear and the belt and on the front pulley maybe 1/8th to the front edge. The position has held firm. The position it's in now it clearly would have been rubbing had I not cut it back.
sixty5pan
09-11-2011 08:57 PM
BigLen
05-06-2011 10:10 PM
dert
08-08-2006 02:08 AM
