vss question
vss question
I have a question if anyone can help. I know a 07 softail has a 5v speed sensor. How do you teat the resistance of the sensor... having an issue with the bike low voltage codes for the map and tp sensor. I have checked wiring resistance and all. The 5volt power from ecm has splices to all 3 sensors. And I'm getting a weird resistance on the speed sensor. I know on a 2 wire you can check the resistance of a speed sensor and it could be out of limits thats why i ask what the value is or how to test a 3 wire
