Help. Shifter not resetting
Thanks for reading . I have a 2009 streetglide with the 6 speed. Sometimes when I shift, it doesn't go in to the next gear. It feels like it didn't reset after the previous shift . When I go to shift the lever just seems extremely free. Once I go to shift again it shifts right up . And it also seems like it's doing it between 2nd and 3rd (not 100% positive it's just then) I took the external linkage apart, cleaned everything up . The lever coming off the spindle on the trans seemed real loose and wouldn't tighten so I replaced that. Still having the issue . Any ideas ?
cwsharp
08-22-2022 11:54 PM
Next In Line
04-07-2015 04:51 PM
