89 electroglyde clutch inop
Driving home I noticed that the clutch cable outer housing broke. I replaced the cable but when I tried to engaged the clutch, it did not budge. I put a pry bar over the push rod on the right side of the case and it did not go in. THe book is not clear about how the push rod works through the transmission. Could the clutch be frozen on the left side of the transmission?
Thanks to Dan and Shadowchrome for explaining how the pushrod moves the clutch plates on the left side of the transmission. It turns out that I removed the clutch cover and found that the clutch shell is hanging low. At this point I'm thinking it's the bearing behind the clutch shell. Big job coming up for me on the Hog.
mi2az
08-01-2011 06:03 PM
