Clutch Adjustment - Torquing Needed?
I own a 2011 Electra Glide which is due for it's 5,000 clutch adjustment. In the past I've had the local HD perform this adjustment but thought maybe I'd save a little $ and do it myself. I've read the service manual regarding this adjustment but have a question. The manual indicates the clutch adjustment jam nut should be torqued to specific in-lbs. My question is - is it absolutely necessary to torque this nut (which appears to be a challenge) or can I just tighten the jam nut until it's tight against the plate (while holding the clutch adjuster screw with an allen wrench so it doesn't move)? Thanks!
RLJ
RLJ
You can buy an 11/16" socket with a nut on the end on Amazon for this purpose. Just a few bucks and saves loads of hassle.
http://smile.amazon.com/gp/product/B...ilpage_o05_s00
