Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Can I use an impact gun to remove the nut after liberal heating for the red lock tight without damaging the trans? Lefty loosey righty tighty of course. I've broken a breaker bar and socket adapter so far.
A 3/4" air or electric impact usually works. A little heat to overcome the red Loctite and the penetrating oil will also help. Repeated short burst on the gun, don't just pull the trigger and sit on it.
