Primary/Transmission/Driveline/ClutchFind answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Had the N1 OD6 tranny installed on my 06 Deuce-no neutral light. Found an article that said 00-06 softtail requires silver bodied switch- installed new switch-Neutral light now on the time. any suggestions?
no, light is on all the time, tried to shim it out, but still couldn't get light to go out
to clarify-stock black body switch -no light, silver body switch (listed for Evo models) light always on
The switches are either normally open or normally closed if the light is on all the time something else is going on there. The switch you need, the 33902-98 is a normally closed switch meaning it is in contact with the drum in every gear but neutral. In neutral it drops into a divot and closes the contact to light the light. It sounds like you have a normally open switch that is not opening enough in the neutral position.
It is not a Harley switch, the shop ordered the switch, will get the Harley switch and see if it solves the problem, Thank You!
a little concerned that with either switch, I have no light everywhere, or lit everywhere.
